Sony RCD W100 CD Recorder
GELÖST
DAVESWIFT49
Neues Mitglied
When i press record the CD wont Record the same with Vinyl on Turntable Iam using CD-RW  Could someone come on Video chat tommorrow evening and go through with  me On Facebook  [edited by moderator to remove personal details] cheers
17 ANTWORTEN 17
Mickoz1974
Mitglied
No worries glad to help, this is a great unit but can be awkward to get used to
David122
So After I Recorded I Finalise Then take CD Out Of CD Recorder Put into Laptop On Windows Media Player The Put the Song Title Eg Zanadu Olivia Newton John then ois   on CD So I can Have it there Or to MP3  player|\\\?
Mickoz1974
Mitglied
Ok if you don’t type he name into the cd player before finalising you will need to edit it on a program that can id3 tag like EAC, iTunes, any burn or other cd rippers, you will need to do this on a device with a cd drive and internet 🛜 with the software, most of the programs allow you to manually type tracks in if there program wouldn’t do it automatically
David122
>From You tube To Windows Media Player I Have Used y2 To transfer Windows Media Player
Mickoz1974
Mitglied
Windows media player will let you edit track names after and before you rip them. I use EAC OR Anyburn Google them. EAC Exact Audio Copy, it takes I bit of setting up but instructions are on Google as well.
David122
Thanks Now Theres Another issue With it When I Enter The Labelling On The Recorder It says number 1 so When I record From Vinyl it does Not Say  track 2,track 3 track 4 And Track 5 As  More Than 2 tracks on it II recorded 5 Tracks
Also When I label The tracks It would only let me put 2 tracks on it It would not let me put other tracks on it.
Mickoz1974
Mitglied
Turn L.sync off and do the tracks manually by pressing record after each track, if you don’t have the time set on total cd and use single track time you’ll see the tracks count up every time you press record, minimum 7 secs between tracks. Make sure make disc is off or it will finialise after digital cd to cd recording so you can name tracks
David122
I record the Whole album vinyl  but it says 1 which is the whole album.
