Questions about the V90DW music system?
darlek1
Hi
Is it possible to switch off the loud beep when using gestures with the 90DW music system?
Is is possible to switch off or dim the bright white buttons on the control panel (tv/dvd/fm etc.)?
Is it possible to switch off the loud announcement when blue tooth connects and disconnects?
Thanks for any help
Joe_Dohn
Specialist
I think what you're looking for are Power saving mode on page 29 and Voice Guidance on page 66 in the Manual.
Not sure if the power saving mode would affect the lights on the buttons, and almost certain beeps cannot be turned Off, but that's what you can change from what I could find.
Hope this helps!
- JD
