- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
AV STR-DN1080 time to time wake up from sleep mode
Hello, I have system TV XE9005 and AV STR-DN1080.
TV and AV connected with hdmi arc cable.
Everything works fine TV controls AV switching on and off power volume and other function.
But after power off TV AV go to stand by mode everything goes fine no after ~15-20 min AV it's coming on running ~1-2 min and and it's coming out and so repeatedly.
Can help resolve this issue?
Thanks for the reply
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Welcome to the community.
I would suggest you contact support here for advice about your AV switching on and off.
Best wishes,
EdwinaU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You probably have a phone paired through bluetooth with your receiver. Try to see if you have a setting on your phone to disable your phone from automatically conecting to the receiver, or perhaps even better, switching off your bluetooth on the phone to see if the problem is solved. If that doesn't work for any reason, what you also could try doing as a test is to turn off this setting and perhaps even this setting to see if your problem gets solved.
