Transfer Sony Reader Library to another computer
profile.country.nl_NL.title
rovanee94
Besucher
I'm preparing a move from a Windows PC (Windows 7) to a Mac.
How can I transfer my eReader stuff so that I still own the books once bought?
Regards,
Rob
1 ANTWORT 1
profile.country.en_GB.title
Convergence
Besucher
Hi First you will need to de-authorise the Reader from the PC, this can be done in the software, which are you using?
Then install Reader for Mac and make sure you use the same Adobe ID you used on the PC, once authoried connect the Reader and authorise it to the Mac, this should re-enable access to the epubs, if however it does not you will need to delete them and re-download them from your stores, they will reactivate any inactive links if you ask them and explain why
