I tried yesterday, 28th february, to install Reader for PC on two computers.
Both installations went well but the software will not even start.
I noticed that the software is a new version so my question is whether there are more people facing the same issue? Is there any advice how to overcome this issue?
dont bother with it. use calibre instead. may need r4pc to open drm files but otherwise use calibre.
I've installed R4PC without problem, only thing I can suggest is to remove it and try again.
I tried a number of times without any result.
I'll try to install the software on a third computer on which this S/W has not been installed before.
I finally have the S/W successfully installed. But now I discover that R4PC does not like to handle too much books in the Library. Response takes minutes !!
thanks, I did!
