Xperia E4 problem with applications
Ale23
Mi teléfono se apagó debido a la batería, así que lo cargué como siempre, pero al prenderse vi que faltaban algunas aplicaciones en la pantalla de inicio, entonces busqué en el menú o eso, y tampoco estaban. Fui a ver a la play store y vi que estaban instaladas, hasta podia abrirlas, comprobé esto yendo a almacenamiento para ver que efectivamente estaban instaladas.
El problema es este: no me aparecen como tal, pero estan instaladas. Ya lo reinicié un par de veces y sigue igual. Aunque algunas aparecen y luego reiniciarlo se van y otras que antes no se veian aparecen, es todo un rollo.
My phone was turned off due to the battery, so I loaded it as usual, but when I turned on I saw that some applications were missing from the home screen, so I looked in the menu or that, and they were not. I went to see the play store and saw that they were installed, I could even open them, I checked this by going to storage to see that they were actually installed.
The problem is this: they do not appear to me as such, but they are installed. I already restarted it a couple of times and it's still the same. Although some of them appear and then restart it, they go away and others that were not seen before appear, it's all a pain.
GT
5 REPLIES 5
jinxycat
The apps that disappear from your home screen are moved on the SD card, if you have one in your phone?
Ale23
Sí, tengo una. Las tengo que mover al teléfono?
Yes, I have one. Do I have to move them to the phone?
GT
jinxycat
yes, try to move the apps to your internal storage and see if the problem is fixed.
Bipin2
My Xperia e4 cannot update new version
jinxycat
Could you elaborate, please?
