As you can see on your screenshot your network coverage it's terrible and you have WiFi on all the time.
Screen was on, probably you was running some resource intensive task that probably had the phone to heat and when that happen you can have the phone connected to the charger but the device as protection measure disabled the charge hence the sudden power off.
Hi @Aweaomesause,
Welcome to the community!
I'm sorry to hear that.
My first thought was that something might be wrong with your battery, but as I understand it your phone is now working again? Is this a reoccurring event that the battery discharges from 70 to 0% in a short period of time or was this a one time event?
It's hard to say the exact cause for this after it's already happened but as previously suggested here it's not impossibly related to your network coverage.
If this has happened several times, have you noticed any pattern as to what might be causing it? For example, starting a specific application or performing a specific action.
If this has (so far) only happened once, please keep monitoring your phone and let me know if it should happen again!
I've had the same situation with my phone. It turned off suddenly when battery was around 70% with this icon of low battery on the screen. It happens recurently. Please see the screens.
Did anyone have the same problem and mayby know how to solved it? Battery is worned out?
I've tried everything. Reboot, restart. Nothing helps.
Bonjour
J ai la même panne identique aux captures d écran
C est tout les jours que ça se produit
Avez vous une solution ?
J ai déjà réinitialisé mon téléphone
Merci d avance
Hello
I have the same failure identical to the screenshots
It is every day that it happens
Do you have a solution ?
I have already reset my phone
Thank you in advance
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Even I am having the same issue.battery is not even holding itself for an hour and its taking 5 to 6 hrs for full charge.but discharging in minutes.suggest me something. What should I do.we are losing faith on Sony.
