- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I had followed the same instructions to unlock my Xperia E(c1504) bootloader and it was successfully done
but when i booted it , it was stuck in boot loop [ i.e Sony logo >> Xperia logo >> animation (6-9 sec)>> screen off >> ......repeat] I also tried of after removing the battery ,but again stuck in boot-loop .
and the flash tool is not detecting my device nor in fastboot nor in reboot.
Please Help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Guys , i am done with Sony mobile flasher by Androxyde
flashed and cleared user data
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can any help be found in the Sony help center or service center
Poastal code - 110089
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My Sony Xperia E (c1504) is not in the supported devices list at https://developer.sonymobile.com/open-devices/flash-tool/supported_phones/
Please help !!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I recommend using Xperia Companion Software. It will fix your issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@uliwooly:
Xperia Companion Software will flash the whole System Software and help him leaving the boot loop.
It will not relock the bootloader.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Nope, it won't work, as long as the bootloader remain unlocked, XC won't work, it won't recognize the phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Got an unlocked X and XZ, Xperia Companion Software works for both unlocked devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it won't work if the bootloader its unlocked, if the phones are unlocked from a carrier network then XC will work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Ankit20
I guess your tried recovery mode?
Entering recovery mode by pressing the Power button+Volume up button and hold, till you get a screen which is the recovery screen. Now, you should be able to see options like Wipe Cache, and Factory reset. In order to get out of this bootloop situation, first tap on Clear Cache.
Then tap on Factory reset.
THIS METHOD WILL DELETE ALL USER DATA.
Otherwise, give Xperia Companion a try (yes it works with unlocked bootloader, i just used it last week to fix my X which has a unlocked bootloader).
