Wifi on the phone itself turns on. Ie if I even turn it off, then he turns it on when there is an available network. Sometimes in order to update the application. What to do in this situation? Sorry for google translate
_____________________________________________________________________________________
Wifi на телефоне сам включается. Т.е если я даже его отключу, то он сам включает его, когда есть доступная сеть. Иногда для того, чтобы обновить приложения. Что делать в данной ситуации?
Hi @Veliam,
I'm sorry to hear this.
I recommend that you reboot your device to safe mode to see if this behavior is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
Also you can try to turn off automatic update of your apps in Google Play Store. To do so, go to; Google Play Store > Tap the 3 lines in the right corner > Settings > Auto-update apps > Do not auto-update apps.
Let me know how it goes.
