Hi @AlanMartins, sorry to hear about this.
I'm not quite sure that I understand what behaviour you are experiencing with the settings application, would it be possible for you to elaborate a bit? Is the application not starting as it should?
If that is the case, try restarting your device in safe mode and see if you are able to launch the application when downloaded applications aren't loaded.
Let us know how it goes!
I only use the option to clear the cache in the only storage configurations. |
