- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
After updating my Xperia E1 on Android 4.4.2 (Kitkat) my Facebook App was automatically uninstalled. If I want to install the app from Google Play Store I get the Message "Incompatible Version" and the installation is aborted. I shut down my mobile, removed sim-card and battery put both in again and than started the phone again but that changed nothing. A repair over PC Companion failured also due to no available software. Can you help me? thanks a lot:smileysmileythumbsup:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Clear data for google play app and try again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
greetings.... i just want to know how to install facebook apps in xperia e1 dual kitkat, i cant install the apps in the appstore ita shows error, any help or suggestion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just go to settings-apps-all-google play,force stop and clear data.After this,log in with your gmail account.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
were hundreds done upgrade to this phone with the same problem, never say its a problem in updating, please give as updates for this matter to fix this kind of problem thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for your help. I tried the PC Companion again. I selected the repair mode and installed the update again. After that, the facebook app was already installed and working. But beware: The data backup, you have to pass through the repair, does not work as it should. I lost all my installed apps. After installing again, most of the data could not be recovered, so I had much data lost. Even after severeal backup repetitions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Done the PC companion update. restored FB but deleted loads of other stuff. Did back up & restore but pretty much having to start from scratch as made loads of changes in last few weeks since did last back up. Update was spot on apart from FB fiasco. Now wish I'd never done the update 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Having the same issue, except I can't use the PC tools as using a Chromebook so unable to download the file.
Any suggestions ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We are currently looking into this issue but at the moment i can only recommend that you perform a repair of the phones software using PC Companion or Bridge for Mac.
Are you sure that the repair was finished and that your phone was reset when you started it after the repair?
@janer
At the moment i have no other solution than to perform a software repair. Could you perhaps borrow a PC or Mac from a friend?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same issue here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have this problem too. I see Facebook has released an update but this hasn't changed anything - I am still getting 'incompatible update'. Sony - this really isn't doing anything to improve my opinion of you...when are you going to fix this issue?
