Hello, some time ago the phone started to fail, when I tried to connect to WIFI in the Settings, I was not allowed to activate the "WIFI" option, when I gave it the tab in YES to activate but not activated, at first I turned off the phone but now I can not even activate the WIFI to see my network and connect to it, I hope someone understood me and can help me with my problem, thanks.
Hi @xJoose_FC
Welcome to the community!
Sorry to hear about that
Can you start your phone in safe mode and see if you can activate and connect to wifi while in safe mode.
Let me know
Nothing, still do not let me connect to the Internet even in "Safe Mode".
Look my problem :c
Thanks for giving that a go @xJoose_FC
Next I would suggest trying a software repair using Xperia Companion.
Let me know how that goes
I already do the software repair on the phone and still it does not let me connect to a WIFI, I get the same problem, I can not even connect to BlueTooth.
Hi @xJoose_FC
Thanks for trying that
In that case it does sound like this could be a hardware issue, I would suggest getting in contact with you Local support and they will be able to assist in getting your handset booked in and repaired.
Good luck
