Calls through bluetooth
Jose401
Buenas tardes. No puedo  activar audio de llamadas en un manos libres Bluetooth. Mi mujer tiene el mismo teléfono y no le pasa. Alguien sabe por que. Gracias
Good afternoon. I can not activate audio calls on a Bluetooth handsfree. My wife has the same phone and it does not happen to her. Someone knows why. Thank you
2 REPLIES 2
Uliwooly
@Jose401
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What if you factory reset the handsfree device?
Kaipiri
Yo tengo el mismo problema con el manos libres del coche...el teléfono no me permite darle permiso para compartir el audio aún teniendo la opción d compartir audio...encontraste solución?
I have the same problem with the car handsfree ... the phone does not allow me to give permission to share the audio even having the option d share audio ... did you find a solution?
@Kaipiri
