XAVC-S with DSC-HX90V
aenimal46
Hello,
when I try to record in Sony's onw format XAVC-S, i get an error message which tells me to use an SDXC Class I or UHS I memory card.
I use a SanDisk Extreme Pro 32GB SDHC Class UHS-II, U3 card. Shouldn't that be enough?!
It should be fine even to shoot 4k video, I just want to record XAVC-S 1920x1080 50p (50M)...
Please help / do other users experience similar things, or, what memory card do you use in order to shoot with the mentioned format?
Thank you, all the best
Felix
Jonnie1266
Contributor
Hi aenimal46,
I use this memory card here
I have a FDR-AX53 camcorder and the card has worked for both XVAC S HD & 4K recording successfully. There is a newer version of this card available which one would imagine may be faster ??
If the camera is not accepting the card can you try another one ?
Regards
If it ain't broke don't fix it
