I have a wx100 and when I try to see the images that taken before using the play button it doesn't display the images. It keep displaing "Accessing..." on the screen.
Any ideas how to fix this?
Thanks
Message was edited by: KasunV
Hello KasunV - Welcome to the Sony Forums
To see if there is anything wrong with the memory card itself, have you tried removing it from the camera and then inserting it into a USB memory card reader on your computer. If you do not have a reader available, most larger supermarkets and photography shops have kiosks available where you can insert the memory card and see your prints on screen.
Thanks,
Simon
