DSC T2 vibration
profile.country.el_GR.title
didivavi
DSC T2 vibration
hello
ia have a DSC T2 Camera. When I turn my camera on there is a vibration noise and the picture is shaking and unstable. Is there any way to fix this or is it a faulty component?
profile.country.en_GB.title
blaireau_photo
Hello didivavi :slight_smile:
The only thing I can suggest, other than getting your camera checked out/repaired, is to try and reset the camera to its factory settings so see if this resolves the problem. With the T2, if you press the 'HOME' button and then choose 'SETTINGS', the 'INITIALIZE' option is located under 'MAIN SETTINGS 1'.
If this doesn't work, there is probably an internal fault within the camera and to find out more about whether a repair would be viable, you can contact Customer Services at Sony using the contact details in the following forum thread:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon
