DSC-HX60V - lens stays extended
SmithPM
My camera is stuck with the lens extended. I tried using a different battery, plugging in the charger, and resetting the camera to the factory defaults. When I do the latter it retracts the lens and then extends it again, but the power button does nothing. Is there no on-line support?
IamNic
Hello @SmithPM,
if I understand you correctly, you tried everything suggested by this  troubleshooting-guide?
The Sony Cummunity IS the online support.
If you want I can escalate your issue to the support.
- Nic
