DSC-HX30V wi-fi won't connect
profile.country.en_GB.title
joemanco
Just bought the Cybershot DSC-HX30V, like the camera but one of the main reasons i bought it was for the wi-fi feature. The camera appears to connect to the router but when i try to upload photos all i get is 'connection error'. Not sure if it's the camera or the pc (am still running on XP). Have installed Play Memories Home and have connected and uploaded photos via the usb connection. Any help would be greatly appreciated.
Tags (1)
20 REPLIES 20
tetrapackage
I've been getting this problem every once in a while and it will connect after 5-6 times. Sometimes it won't at all. I am just not sure if there is a problem with its WiFi feature or somewhere else.
Mick2011
Hi joemanco, welcome to the Sony Fourms :slight_smile:
The wifi should be quite easy to set up, following the instructions in the user guide. I wonder if you're trying to upload the full-size file? Wifi on the HX30V is only intended for viewing on the PC and uploading to smartphones and image-hosting websites, for which a smaller (ca. 2Mb) file is created. The full-size file is supposed to be transferred via USB.
If this isn't the problem, can you describe at what point the error message appears?
Mick
joemanco
Hi Mick,
Thanks for the welcome.
The camera is definately connected to the router as I have checked the MAC address of the camera on the router, when I try to upload a picture to the pc the camera screen displays connecting to Pauls PC. it displays the SSID address and says its connecting, it does this for about a minute and then says 'network error occured'. I have connected the camera via usb and checked that it is 'registered' for wi-fi  in Play Memories Home which it is. I do not get any firewall or anti-virus message so I don't think it is being blocked also regarding file size I didn't see anything relating to file size as the whole point of the wi-fi connectivity was to be able to upload your images wirelessly.
I bought the camera on-line from Hong Kong and when i tried to register the product here in the UK the only option it gave me was the DSC-HX20V, I have also contacted Sony support UK and they seemed to be a bit unsure when i said it was the HX30V so I am starting to wonder if this camera is not yet available in the UK/ Europe and if it is a firmware/software issue. Sony said they would call me back which they haven't as yet.
Paul
adama1980
Hi
Did you find a way to resolve this, i also am having the same problems.
The camera is connecting to my network fine as I'm able to view pictures on my smart tv, however, when i try to 'send photos to computer' it just times out with 'network error'
I'm using a mac rather than windows so it sound like this isn't OS specific
Mick2011
Hi adama, welcome to the Sony Forums :slight_smile:
I'm pretty sure you need to use PlayMemories Home to use the WiFi features, and as PMH isn't available for the Mac that would likely be the source of your connection problem. I think you can get a lower resolution transfer to work with iPad and iPhone apps via PMH Mobile, which is available for these devices.
It's early days for camera WiFi connectivity and the HX30V is an early impementation of it, which might explain some of these problems. It would be good to hear back from Paul, as the WiFi functionality may currently be restricted to smaller filesizes; I could be wrong of course, but that's the feedback I've had.
Mick
adama1980
HI Mick, thanks for the response.
It should be possible on a mac as they've written specific software to do it:
I've been following the guide here:
http://esupport.sony.com/docs/dvimag/Wi-Fi_Import_Help_for_MAC/en/index.html
It seems to be set up ok just won't connect.
Mick2011
Ah ok, interesting ...
It's possibly a DNS issue with your modem configuration. I'll check on some Mac forums and see if there are any pointers.
Mick
joemanco
Hi Adama1980 and Mick,
I never got the wi-fi to work on my old pc running windows XP but last week got a new pc running windows 7 hooked the camera up installed the software on the camera and the wi-fi works every time. so the only explanation I can give you guys is that it must be OS or Spec related or Sony have updated the software.
Hope this helps
All the best
Paul
Mick2011
That Sony webpage will help you set up the camera as a designated device on the Mac, but the 'everyday' connection is performed from the camera Play mode, according to solutions I've come across.
This thread seems to have the most comprehensive advice and futher links to HX30V users who have successfully connected to their Apple devices: https://discussions.apple.com/thread/4073344?start=0&tstart=0
Hope something there works for you :thinking:
Mick
