DOES ANYONE KNOW IF THERE IS ANY MAC OS X 3d EDITING SOFTWARE FOR THE SONY HDR-TD10 3d HANDYCAM , HAVING SHELLED OUT THREE YEARS POCKET MONEY I AM NOT A HAPPY CHAPPIE , C/MON SONY YOU AND MAC ARE TWO OF THE WORLDS TOP BRANDS....
Message was edited by: cassoplad
Hello cassoplad
Would a piece of software like RevolverHD be suitable for this purpose? It lists 3D editing / export amongst the available features and although there is only a mention of a Panasonic 3D camera, it may be worth contacting their customer support to see whether there would be any compatibility with the Sony model:
http://www.shedworx.com/revolverhd-features#rhd-3d
Thanks,
Simon
Hello cassoplad
Thanks,
Simon
Hi There,
I would seriously suggest using Sony Vegas 11 to edit the output, the only problem is you will then need a Bluray Authoring program. The main software types are:
Sony Blu-print v 6 - c. $96K yes thats 96,0000 dfollars !!
Netblender Dostudio - c. $6K
Scenarist BD 5.7 - c. $49K
In reality the software has not kept up with the hardware - or at least at a price consumers can use.
The only real way to produce BD3D disks at present is to use Cyberlink Powerdirector 10 Ultra c. $100 yes thats only 100 dollars - however whilst it will produce BD3D it is certainly not as slick as the above.
I have used it and for a basic BD3D with Menus it does a reasonable job - but it is limited!
Also the european version of this cam TD10E cannot output the 3D video at 23.976 - which is the requires out put for full HD BD3D - all this means you cannot produce real BD3D films using this camera if you have the european version.
Regards
Spear01
Funny... Sony site recommending to use Panasonic's software... sheez
