Hello merrick22 - Welcome to the Sony Forums
As this is an analog format camcorder, the only way to connect it to a PC would be using a USB video capture device, such as the EasyCap. You use the existing video output cable that was provided in the box, and insert the leads into the USB device. This usually comes with basic capture software, or Windows Live Movie Maker will also do the job. Your PC will then capture the video in real-time.
Thanks,
Simon
Thanks,
Simon
