HI
I have the above and want to record from the TV.
As per the instructions I have the AV cable connected to the TV, have slid across to play mode, with the next step being press p-menu then rec control. The problem is I do not have an option to press record control. Does anyone know where I can find it?
Thanks in advance.
Hi robwise, welcome to the Sony Forums
Have a look at this FAQ which covers all kinds of handycam.
It may be that you need to scroll through some sub-menus in the P-Menu, or it could be that you need to hit [Menu] again to bring up the Rec control function:
http://www.sony.co.in/support/faq/140112
Mick
hi
thanks for your help.
when i slide to play / record and press p-menu i get the following options -
volume
data code
lcd bright
set up
display
hdd format
hdd info
tv type
language
disp output
beep
calibation
p-menu set up
i have been through everything but I cannot find record control.
does anyone have any idea where this elusive option is?
thanks
Bump
Surely someone knows the answer to this please
