i have a handycam dcr-dvd105
i am trying to record cine film that is projected into a camlink converter
the problem i have is that the recording flickers
i need to adjust the shutter speed to 50 but the camera only seems to allow auto or off
is there a way of setting the speed to 50
apparently you can not set the shutter speed manually.
You can try to use the Program AE with some of its scene modes. The sport mode is designed to use fast shutter speeds.
