i just wanted to watch films on the beamer of the PJ10E that where not recorded
with this cam. i thougt that would be easy. but its not.
thanks,
Freanta
Out of interest, have you tried rendeing the footage as Sony AVC? I do not have one to hand but best to stick the footage in the PRIVATE/STREAM folder (sorry I do not have one at hand to confirm the folder).
In order to view on the camera other footage or edited footage you have 2 stepts to follow:
1. export footage in Sony AVCHD fromat suported by your camera - if you have Sony Vegas it has this format supported for export
2. use the PMB software provided with the camera and export your footage directly to your camera memory or to an SD card that you will insert it later in the camera - you need to do this step because this software will create all the links to the file in order to the camera to find the file, it doesn't work just to copy the file in the memory/SD card
