HDR-FX7E 64-bit Win 7 device unplugged issue via i-link
profile.country.en_GB.title
parasound
Hello,
I have a Sony HDR-FX7E camcorder and i am using win 7 pro 64-bit OS. When i connect my cam to pc via fire wire (i-link) the device model appears in an installation window and win 7 recognises the model name. It however tries to install a driver for it although Sony states that via i-link connectivity does not require driver.
Then this driver is not found and the message says device unplugged.
Please help if you run into similar problems
Thanks
profile.country.hr_HR.title
DamacizSi
I am not suprsed by 64-bit running Windows
U can use Windows Movie Maker via I link cable which protocol is IEEE1394. On program you go to function chaptering from video device, which is first left in program. On camera set option play-edit.
http://explore.live.com/windows-live-movie-maker?os=winxp
There is free download on internet, if You use Windows 7
There are 4-4 and 4-6 pins I link cable. Sony cameras are always 4 pin, but see DV IN in Yor PC. If You do not have DV IN, there are cheap USB - I Link adapters.
Deinstall K-lite and free codec packs.
Regards
Damac
:slight_smile:
