With the camcorder switched on, when I open the LCD screen it is blank. I can see an image in the view finder. When I rotate the LCD screen 180 degrees the screen comes to life, displays the image and the touch controls.
Any ideas on what the fault is?
Hi rainford - it does sound like there's a broken connection there. If the LCD's faulty it'll not work at all.
You could do worse than contact Sony Support and see if a repair would be viable.
Good luck with it
Mick
Hello rainford - welcome to the Sony Forums.
When you say that the screen goes blank, does it look like there is any power running to it i.e. blank but lit up white/blue or is it totally blank and powerless?
Thanks
Simon
Simon,
The screen is blank whether the power is on or off - no signs off life. However, with the camera turned on and the LCD screen open and blank if I rotate the screen through 180 degrees the LCD screen springs to life and displays everything as normal.
I'm not sure whether the fault is with a flexible ribbon connector or the LCD screen.
Bob
Good luck with it
Mick
