Will Factory Reset unistal system update
kcube
Will Factory Reset unistal system update. I mean update like 16-0-b-2-16 will go if I do factory reset.
Rickard
Master
A master reset will not remove an update of the phones firmware. When you install a firmware update it replaces the old version or the firmware and can't be uninstalled.
2 REPLIES 2
Rickard
Master
Thommo
It will factory reset to the same version you have installed now
