Transmission problem from internal memory to external
Hoseins333
سلام از فایل منیجر نمیشه انتقال داد به کارت حافظه خارجی نه کپی میشه نه انتقال ولی از کارت حافظه میشه انتقال داد حافظه داخلی
از درون تنظیماتم میشه ولی از فایل منیجر نمیشه  کارت حافظه فرمت کردم فایل منیجر مختلف امتحان کردم نشد
Hi from the file manager can not be transferred to the external memory card is not copied nor transferred but can be transferred from the memory card Internal memory
I can not find my file manager. I did not download the file from the file. I did not try the file manager.
gt
Uliwooly
@Hoseins333
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What if you install a file commander then transfer the files, also what are you trying to transfer?
