XG9505 TV Channel Info issue
profile.country.FI.title
liripiri
Hi all, I have a relatively small issue with my new XG9505 TV, but for me a very annoying one. When I browse through the channels, I usually look at the top info bar where you see the channel name, currently running program name, time, description etc. The problem here with the info bar is that when the channel changes, it at first shows the program name that was previously running and if the program has changed since the last time I watched the channel, then in about 1 second it updates the program name to the currently running program name.
I wish Sony would fix this issue so that when you change the channel, you would only see the actually currently running program name and not what ever was previously there. It makes channel flipping slow since you always have to wait until the program name is updated. Thank you.
rooobb
I do not now if it helps, but have you tried setting the automatic update of the guide in standby?
