- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a Sony soundbar HT-X8500 and a Sony Android TV KD-49XG9005BU. I have connected these via the eArc connection using HDMI. I purchased this HDMI cable https://www.amazon.co.uk/gp/product/B07KWNPZ1L
Now, the following happens frequently when viewing TV (either internet streams, cable etc.)
- the TV output continues to randomly switch between the TV Speaker and Audio System (soundbar).
I have no idea why this is happening.
Has anyone experienced this issue before please?
Thanks
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all
I need to share the outcome/conclusion on this topic as I discovered the root cause of the sound switching between TV and soundbar audio output.
It has also taught me a lesson to consider all options rather than just an issue with the device (soundbar).
I upgraded the Sony TV to the latest Android software but the sound switching issue persisted.
After a while, I decided to unplug other devices from the TV one by one. I unplugged a Humax Freeview box 5000t from the Sony TV (HDMI connection). Ever since doing so, the sound has never switched devices and has been flawless for the past 4-5 months. I have concluded that the always-on Humax Freeview box must have been interfering somehow with the audio.
Lesson learned for me.
Thanks for all the feedback and support to date.
Ben.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If the cable is as good as the supplier’s English, that would explain it.
But what is happening is that the ARC handshake is coming and going; either because one or both devices aren’t keeping it up, or because the cable is faulty.
Try turning it round; try another cable; if both devices are eARC, try dropping to ARC; if one of the two only is eARC, try switching it explicitly to ARC.
Report back and we will go from there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Ben,
I agree with @royabrown2
You would need to use a cable that's compatible with HDMI 2.1 when using eARC.
Your cable is only compatible with HDMI 2.0.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ah - so are we saying that eARC, even just with 4K, requires more than just the HDMI 2.0 with Ethernet which the cable referenced provides?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks @Peter_S.
A couple of observations, after looking at Sony’s specs for these devices:-
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xg9005/speci...
https://www.sony.co.uk/electronics/sound-bars/ht-x8500/specifications
(i) The TV is only shown as having ARC. Has it got eARC in an update, or is ARC only still the case?
(ii) Neither device is specified as being at a certain HDMI level. Perhaps there is more detail in the manuals, or other supplementary material, but how are users supposed to know that they need an HDMI 2.1 compliant cable?
About which I anyway remain deeply sceptical. It used to be that cable manufacturers were actually prohibited from using an HDMI version number when describing a cable, and the key thing was what speed they would support, and whether they were plus Ethernet or not.
(And according to the source I quote at bottom, they still are, and can’t put HDMI 2.1 on cable or packaging; though they can now allude in marketing material to supporting features in HDMI 2.1, like
Auto Low-Latency Mode (ALLM)
Variable Refresh Rate (VRR)
Quick Frame Transport (QFT)
Quick Media Switching (QMS)
But not eARC, as this is supposed to run over earlier cables.
And this is still the case, with HDMI 2.1 now being shorthand for a cable that will run at 48Gbps, rather than the older High Speed of 18Gbps, and will always have the Ethernet wire that is now used for eARC.
But what, in the user’s setup here, with not a sniff of very high refresh rate 4K, let alone 8K, might be demanding 48Gbps? Especially just for ARC, or even eARC.
Also:-
From: https://www.hdmi.org/manufacturer/hdmi_2_1/index.aspx)
Q: What cable(s) do I need to make use of the eARC feature?
A: Ultra High Speed HDMI Cables are designed to support the new eARC feature in addition to the highest resolution video modes. The Standard HDMI Cable with Ethernet and the High Speed HDMI Cable with Ethernet will also support eARC.
eARC
Q: Will this work with any HDMI cable?
A: This works with HDMI High Speed Cables with Ethernet and the new Ultra High Speed HDMI Cable.
Q: Is eARC available through a firmware upgrade?
A: Generally speaking, no. Check with the manufacturer of your product to confirm.
Q: What audio formats are supported?
A: The latest high-bitrate audio formats are supported including DTS Master, DTS:X, Dolby TrueHD, Dolby Atmos and more.
Q: Will the existing ARC-enabled products work with new products that use eARC?
A: Maybe. Manufacturers can produce products that are compatible with both eARC and ARC. However, eARC is not defined to be backwards compatible with ARC.
So maybe the OP’s mix of ARC and eARC is a problem, and the soundbar needs switching down to ARC?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi royabrown,
Thanks a lot for all the details.
So a standard HDMI High Speed cable should work as well.
My thoughts on this issue were that the cable quality wasn't good enough. Then I spotted that the connection was done via eARC which obviously cannot be the case since it's not supported by the TV but the soundbar (see IM).
So guess I've headed into the wrong direction with the proposal to use a HDMI 2.1 cable.
Anyway, I think the cause of this issue is related to the cable quality OR (new suspect) it's because the soundbar is set to eARC which is not supported by the TV. So maybe turning off eARC in the soundbar would be worth a try.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, we are on the same page again here., with the first option to try setting the soundbar down to ARC, and the second a new cable; even though the one he has should nominally be OK, a more established make (and not necessarily a dearer one) might work better.
But while the soundbar should detect the TV is ARC not eARC and drop to ARC only, the effect described could exactly be a soundbar failing to do that, but that keeps optimistically retrying for eARC.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
First of all, thank you for all the replies and insight, this is incredibly helpful.
I did not realise that I have plugged in the soundbar eArc to TV standard Arc. Interestingly, I could not see a way to force ARC vs eARC on the soundbar (after looking at the manuals). I've also been looking at the TV settings e.g. HDMI control.
I will also try a different HDMI cable. Do you have any recommendations please?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Interested to know where this goes! Do let us know.
Win_88
