Screen saver cancels radio.
nibrown45
Nieuw
Hi, I have my screen saver set to come on after a period of 15 minutes of inactivity...all good, untill I want to listen to digital radio on my TV, then the screen saver cuts the audio as soon as it kicks in, the only way I can stop this annoyance is to go back into settings and extend the idle time to one or two hours of inactivity before screen saver comes on, I don't like doing this as the radio station logo could burn in after such prolonged periods.
Is there not a way to have my screen saver running and listen to radio at the same time??
2 ANTWOORDEN 2
LightFoot
Specialist
Hi @nibrown45
The starting point for any attempt to help you is the full model number of your TV. It will start with KD or XR.
Is there a particular reason why you are relying upon a screen saver and not simply turning the picture off.
HannahEd01
Community Team
Hi nibrown45, the screen saver is the thing that will help you prevent the screen burn, check this out: https://www.sony.co.uk/electronics/support/articles/00173479
If you are just keep to stop the screen save, please confirm the model number.
