- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Motionflow issue
I find out something intresting about Motionflow in my KDL 50W755C. Motionflow not work in default or any other players when videofile have aspect ration other than 16:9.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
How do you come to the conclusion that motionflow doesnt work with aspect ratio's other an 16:9? I can test things on my TV as I will have the same firmware version as you and should work the same - if you can provide steps on how to reproduce this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I also have samples where MotionFlow fails. It can easily be determined with samples which include a ticker. When the ticker is more into the middle of the screen, MotionFlow works better compared to when the ticker is more to the bottom. I assume that MotionFlow gives more weight to the center of the image. But that's just wild guessing.
In your case I would have assumed the opposite as the 2.35:1 sample has no encoded black bars, so MotionFlow should probably have a better chance to get it right.
How do you determine whether MotionFlow is working/not working?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Its easy to test motionflow.
- Install VLC player,
- download any 2.35:1 video,
- play it in VLC player,
- in VLC player set motionflow at custom, smoothness at 5 and film mode at high
You will see that nothing change, but when you stretch image in VLC player motionflow start working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
And you notice it by the artifacts and soap opera effect that it produces at Smoothness=5?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Its only for testing. In stretched 2.35:1video motionflow works and you see soap opera effect, but in not stretched 2.35:1 video no difference if smoothness=5 or off, motionflow not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I now tried your samples and can't confirm your findings. I tried it from within Kodi and applied a Smoothness of 5. Both samples played with SOE and and quite a lot of artifacting.
Kodi asked me to set the 2D/3D mode for the 16:9 sample. So seems like this a 3D sample? I wasn't asked for the 2.35:1 sample though. Probably that's what makes the difference? But then again I would expect the 16:9 sample to fail for MotionFlow.
[EDIT] Used samples in wrong way. New answer here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I checked the samples with MediaInfo...
The 16:9 is H.264 AVC.
The 2.35:1 is H.264 AVC MVC (3D).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried the sample and changing smoothness didn't change anything - no SOE at all.
Generally for all full screen videos without black borders, the picture seems to be more smooth.
