KD 55XD8599 Mobdro
StephenRidge
KD 55XD8599 Mobdro
How does one load side apps like Mobdro, aptoide etc, can it do done using opera browser?
Does the scart socket have audio output if so can this be used as audio output to 5.1 surround system which has  Left/Right RCA phono inputs?
6 REPLIES 6
Anonymous
Not applicable
Hi there
I believe Mobdro can be sideloaded, but you will also need a sideload launcher, such as this one HERE.
In regards to the Scart socket, it will output audio but only via the TVs internal tuner and only 2.0 stereo.  If you have L/R RCA plugs, you will need to connect using the 3.5mm headphone/audio out socket, in conjunction with an adaptor.
StephenRidge
I have been informed by Sony Shop Mobdro not fully compatable with TV, but should work if side loaded onto Amazon Firestick etc.
Managed to get 5.1 surround working by using 3.5m stereo headphone socket on Tv but needed to select sound output from headphone to be defaulted to both sound output from headphones and Tv speakers at the sme time, works a treat.
Anonymous
Not applicable
Further info can be found in this thread - with further links:
https://community.sony.co.uk/t5/android-tv/sony-android-tv-kd-55sd8505/td-p/2284933
Unsure on your 5.1 claim - probably multi-channel stereo?
karankhanna22
Well, I am facing this same problem while using Mobdro App, any solution?
StephenRidge
At long lat I have managed to install Mobdro onto my SonyTV.
First make sure you have downloaded es file explorer and side loader apps and using ES this under favourites - add-figetzip herele enter [Link removed by moderator] name it firetv, on right  panel of es scroll down on  firetvguru web page to media centres click on , when download window opens, open file in es explorer ez viewer, mobdro icon appears, double  click on it to open  select install after accept on welcome page. All this can also be found on a youtube video called mobdro on sony android tv.
Mobdro apk can be found under sony Apps and within sideloader app.
StephenRidge
