43-inch XH81 doesn’t support 4K/HDR on PS5??
wizardbynight
Just got my setup hooked up. Was running the PS5 through my PIoneer VSX-534 amp, and the PS5 was reporting 4K HDR wasn’t supported. So I plugged the PS5 directly into the TVs HDMI port and it still says 4K HDR not supported. It makes me lower the resolution to 1080p and HDR suddenly activates. I’m using the HDMI cable that came with the PS5. Any ideas what’s going on? This TV is advertised as 4K HDR? I’m not happy.
Tags (4)
RottenFoxBreath
Enthusiast
Try changing the hdmi from standard, to extended/expanded, in the tv's settings, or your amp.
3 REPLIES 3
rooobb
You are not happy but did you take the time to read the user manual? https://helpguide.sony.net/tv/haep1/v1/en/04-09_02.html
RottenFoxBreath
Enthusiast
wizardbynight
Thanks for the replies guys. It was my Pioneer amp. I had to get into a menu with button combo on the unit to enable 4K: advanced. All looking sweet now!
