1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Using just the blu-ray player, Netflix works 5.1 just fine, shows all the films and TV show that support 5.1. Just the TV app on the Android sets doesent. Many would just say, use the Player then, but why should I. Why cant we just switch to speakers, press the dedicated Netflix button and enjoy a film in 5.1 from the get go!?
is there a seperate Netflix app that can be added to the TV set by any chance?
I really dont care if Netflix has surround or not, I use it maybe 1-2 times a month for a comedy or doc - but it really annoys me, that PLEX is affected to, cause I have tons of movies on my NAS (I have digitalized my entire movie cataloge since the VHS ages) and no surround for ex. Aliens or any other movie for that sake, is pretty tame... 😞
so just for clarity incase any of support does happen to glance this it is 5.1 sound for all in built apps for the TV.
I also utilize plex a lot and this is important to not just pin point the issue directly to netflix if it is the case.
lets hope this weeks update brings miracles.
I've tested Netflix, PLEX, VLC and traditional tv-signal - all in stereo/2.0 (using HDMI/ARC). So, at the moment.. yes 😕
Don't know if its the same with PlayStation connected to the tv through HDMI - havent tested since the last update
I don't receive any 5.1 through the ARC port myself.
No 5.1 through the Netflix App either... But I don't receive using my PC as well.
I've had to plug my PS4 into the AMP (STR-520).
Ideally I would prefer to plug all my devices to the TV and let audio through the ARC port.
I've reported the issues to Sony Nordic, which will take the matter further to higher court.
I work at a Sony store in Denmark, so I have direct access to the right people - not just customer service
