Sony KDL-40EX505 audio break down
GELÖST
profile.country.de_AT.title
tommobom
Besucher
Sometimes, after watching TV for an hour, audio breaks down for some seconds. (only one time per tv session)
After the break down, audio level increases a little!?
It happens with digital and analogue channels via antenna cable....
Is it normally???
Sony Bravia KDL-40EX505 (with the latest firmware)....
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
profile.country.de_DE.title
SmilingGuy84
Mitglied
this can be a signal problem.
Does it happen regularly after x minutes / everytime at the same time?
Do you use other Sony devices together with the TV? (DVD Recorder for example?!)
Did you do a factory reset already (not reinitializing!)?
I would recommend to ensure this first.
From which company do you get your TV signal?
I would say that this is a little glitch to be solved by a simple reset. Even if you have to search and sort your TV services again.
The TV is nothing but a computer with a big screen today :wink:
Best Regards
Liebe Grüße
SmilingGuy 😃
2 ANTWORTEN 2
SmilingGuy84
Mitglied
Best Regards
Liebe Grüße
SmilingGuy 😃
tommobom
Besucher
Thanks for your advice
The break down is still alive 😞
Nachricht geändert durch tommobom
