Tamron 70-300mm F4/5.6 DI LD Macro Sony to Sony NEX 5
profile.country.en_GB.title
xtentpegx
I have just bought the Tamron 70-300mm F4/5.6 DI LD Macro Sony and the LA EA1, but the autofocus will not work have done both the firmware update on the camera and mount but no joy.
Anyone got any ideas
Mick2011
Hi xtentpegx, welcome to the Sony Forums :slight_smile:
With a couple of exceptions, the LA-AE1 adaptor will only auto-focus properly with a-mount SSM and SAM lenses. Some Sigmas are ok, others (even Sony a-mounters) will only work very slowly, due to the use of contrast-detection AF.
Your Tamron should manually focus and work ok in every other respect, but you'll need the LA-AE2 adaptor, which adds phase-detection AF, to get functoinal AF with that lens on the NEX-5. It's unfortunately a bit more expensive, but if you just bought it new hopefully you'll be able to exchange for the AE2?
Mick
Mick2011
Mick
