Playback Sony A7 IV
TurtonBaslow
Playback Sony A7 IV
We have set up the camera to record photos to Slot 1 and video to Slot 2; when you come to playback the photos and videos you can't view the content on Slot 2.
On my Nikon D500 I could view all the content on both cards. Does anyone know if Sony is planning a firmware upgrade to allow seamless playback between both slots?
I know you can allocate a function button to allow the viewing of content in Slot 2, but this is a step back from what I had on the Nikon. Plus, all the function buttons have been allocated.
Any comments would be much appreciated. Best, Simon
danardeng
Contributor
Here to select the slot you want to play
https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000649103.html
Actually I don’t remember if there is the ability to assign to a custom case, in case you can assign in only playback mode, so you doesn’t lost your preferred function in capture mode.
https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000655376.html
I agree that the sony’s management of flash cards is not easy (from the presence of a database, to the strange folder structure), but that it’s.
If I remember well on newer pro cameras there is a firmware update that enable an easier switch, so they know. 🤷‍♂️
Finally: no, it isn’t a downgrade from D500 (that I know), the A7iv (that I well know too) is absolutely a great upgrade. But for sure if you are looking for a nikon inside a sony you can’t find it
