Memory card slot (1) won't let me insert a card, any help?
And what Memory Card?
Manolo
Hello @Marino.Manolo,
since all Sony photo cameras use full-size SD-cards, I assume it is one of this type - unless OP tries to enter a Memory-Stick or another card format.
- Nic
Some Alpha Memory Sticks accept them in fact.
Manolo
if I recall correctly, the alpha-cameras of the last four years only support SD cards.
Some other Sony cameras though still sport a "dual" slot where you can enter memorySticks or SD-cards - e.g. the Sony Action Cam.
- Nic
Slot 2 of the Alpha 7 and Alpha 9 for example also supports Memory Stick.
Manolo
Hi @Marino.Manolo,
you are right, Slot 2 does.
The last alpha camera I bought only had one slot and that is SD-only.
- Nic
... Suspense...
Manolo
