We constantly strive to improve our products, so we’d really appreciate your feedback on what changes you would make to your Sony DSLT camera to make it even better. Whether it’s to do with the design, usability or specific features just let us know what camera you use and what changes you’d make.
The cover for the USB connection only just allows the USB plug to fit in. It seems like the flexible plastic "hinge" might break soon when used regularly.
I second that!
Digital level gauge added to the A35 please. In fact, I was quite dissapointed to find that the A35 does not have the digital level gauge, despite the sony website saying that it does under LCD on the A35 specifications page.
Hopefully this will be added as part of a future firmware upgrade?
I agree totally. If you use shutter priority settings the 10fps is not achievable and the EVF / screen goes black mid way through rapid shooting which is very very very irritating when I'm trying to take shots of fast moving aircraft. I use a Sandisk 16GB Extreme 20MB/s SDHC card and I wondered if I had a problem with it or the camera so I went to my dealer to check if my camera was actually working properly. Apparently it only gives 10fps when set to "auto" and the guy at the dealership queried what the problem was!
The other improvement I would make is to make the body bigger - I have large hands and where my fingers wrap around the grip and my fingertips touch the body I have worn away some of the rubber skin from it - within the first 6 months of owning it which makes me not very impressed!
I consider myself a bit "old-fashioned" in so much as I like to look through the EVF to capture my shot rather than look at the LCD screen. The other reason is that you have more control over "shake" if the camera is held up to the eye and you can balance better to get a steadier shot. Trouble is the EVF is not good for shooting in MF because it is incapable of producing a sharp image so you never know whether its on the money or not until you've taken the shot. I know that the focus point will illuminate green when in focus and the shutter button is held part way down but I'm not always convinced that it is focussed on the actual part of the shot I want!
I would also like to see a dual display - one for settings and the other for live view.
Also why not a number of user-defined saved manual settings that will allow the user to quickly change the settings to accomodate different types of subjects by retrieving them from the memory?
A detachable battery pack that fits on the base of the camera and provides a longer battery life than the standard internal battery?
Finally the flash hotshoe: Why isn't it a standard design to be compatible with other non-Sony devices? Canon and Nikon have a standard design so why not Sony?
Message was edited by: MarkHoldgate
A33 - Simple, just improve the battery life...
Hi, I use the A35 mainly for film.
A couple of firmware improvements would be:
1. Configure a button (say live view) to hold focus while pressed when recording. (some older minolta Xi lenses have such a button)
2. Mjpg is already available - why not allow filming 720p in mjpg? Easier editing on PC and SD card sizes are growing + prices are coming down. Would be a nice choice.
3. More control of settings in video mode, for those of us who do have tripods etc...
Because video is in auto mode, it causes ios/ap lighting problems, flickering etc.. I would prefer to choose a constant setting and accept the cons.
4. AVCHD is recorded progressive (25fps PAL), but seen as 25fps interlaced in editing programs. Would be nice to be able to change properties of avchd file in say PMB.
5.Be able to to activate shutter release button for video filming in settings - thus being able to use a remote. A useful setting would be like on Point and shoot, Hold down the shutter to autofocus, fully press to film. I know it's not the point of a n SLT, but for video, it gives instant control in one button for recording when you don't have time to adjust everything. Professionals use higher end gear, the A35 is Entry - family birthdays etc...
Hope we amatuer film guys get some of the above....
Message was edited by: mikeyp2000
A few more ideas for the A77:
1) Implement a Contrast Detect AF mode for tripod work. I believe the A580 can do this. Even if it's not fast, it would be useful at times.
2) Invent an Auto-micro focus adjust facility. If contrast detect focus (as in "1" above) it should be simple for the camera to calculate the focus shift from the phase-detect AF sensors and set the MicroFocus Adjustment automatically.
3) Allow multiple Microfocus adjustments for zoom lenses (Eg, wide, middle and long end of the zoom range) It's not uncommon for a zoom lens to have different adjustment needs over the zoom range.
4) If I autofocus then use the focus magnifier to zoom in, it's great but if I notice a focus error and press the AF/MF button on the camera so I can manually adjust the focus, the viewfinder is zoomed out again. The same happens if I use the M/AFC/AFS/C-AF dial on the front of the body. It would be very nice if the view stayed zoomed in.
5) Fix the banding issues seen when taking pictures with HSS flash and electronic front curtain shutter or implement an option to disable EFCS when using flash and HSS shutter speeds.
i totally agree with this list of features for future a77 firmware updates. Even considering that A77 is a fabulous camera, all of these fixes could add a perfect final touch to the annoying issues that i'm having after testing it for one month. I specially agree with manual audio level control (and also a on screen audio level meter), a long press or double click over the video recording button (this is really annoying cause right now i record so often 5 sec clips by accident), and also it could be great to allow switch from PAL to NTSC and viceversa, and disable cropping when recording video (even losing the steady shot feature) and allow 2.8 with video recording.
Also RAW panoramas, and HDR in raw mode could be nice.
just my two cents
kind regards,
I wonder, whether this thread is still read considering that not that many posts have been made, yet...
The A57 introduced a cropping feature which enlarges the focal length and increases speed in order to achieve 12 frames per second. I think, this feature should be extended further - a huge advantage of the EVF is that it isn't limited to a fixed display ratio and size and it would be great, if I for instance decreasing the image size, the focal length is extended automatically (e.g. 24 MPix -> 12 MPix make a 18-55 lens zoom to 110.
Another issues, which is bothering A55 users is that HDR mode is disabled, when RAW mode is set - why not automatically disable RAW when HDR is selected? Currently, this is quite cumbersome to do.
Hi, thanks for your feedback! This thread is certainly read - and the feedback provided goes straight into the hands of the worldwide Product Marketing group, so the knowledge we receive goes straight onto the roadmap discussions for future releases!
Many thanks for taking the time to comment - we appreciate your thoughts and contributions!
