Help!!!
SonyA7IV with Sony URX-P03D two channel receiver. All new kit. Audio cuts out after about a minute which is very unhelpful.
Mini Jack input works fine.
Any thoughts?
Thanks.
It might be a compatibility issue really, or an interference issue.
Have you tried the receiver with other devices? Or, did you try to change the location?
I have the same issue; any solution?
