Aptx Tws+ stop working after android 12 update... two updates in fact... Working perfectly on Android 11...
Xperia 5 II no error code, only Tws+codec can't be used
@pynzeta, did it use to work before the update? and what is the headphones model? Have you tested it with any Android 11 phone?
Another update and still the same problem, no aptx Tws+available, my earbuds are a Cambridge audio melomania 1+ and soundpeats s1 .. both Tws+ and both work properly on Android 11.
Did not solve nothing, I do this two times with the same results..it's a software fault... when android 12 update was made someone forget activate the codec...
